صفحه 70 از 674 اولاول ... 206066676869707172737480120170570 ... آخرآخر
نمايش نتايج 691 به 700 از 6731
نام تاپيک: Pro Evolution Soccer 2011
    آخر فروم باز google_boy07's Avatar
    Oct 2007
    قسمتی از صحبتهای UEROGAMER آلمان در مورد بازی
    “All in all, the early version you can not really draw accurate conclusion due to a lot is not finished or not yet implemented. Despite all the innovations, however, leave a good impression and could revitalize the PES series. The main objective of the developer is in any case, recover the trust of the fans. So what is EA Sports over the past years, has excellent hinbekommen at. Sufficient changes will definitely be on and the team seems to be trying really, this time on its previous laurels not. If everything works, how to make the imagine, could be the duel vs FIFA. PES this year will be something close again.”
    متن کامل اینجا : ( که البته به زبان آلمانی هستش )
    قسمتی از صحبتهای gamestrust دیگر سایت آلمان در مورد بازی
    “As a long-PES-gamer, I was shocked at how many simple and embarrassing bad passes when that happened allude me. After I had gotten used to the system but halfway, I noticed the huge potential of new opportunities offered by the free system. Finally you can play the decisive pass against the direction that has prevented the computer in the earlier parts of the time because he found another pass meaningful. Finally you can play the brilliant side alternating with the striker in the completely open space can penetrate behind the defence.”
    متن کامل اینجا که البته به زبان آلمانیه
    یه حسی بهم میگه اینا مسئله زمان پاسخگویی رو درست نکردن از این ویدئو
    دوست عزیز این به نظر من غیر منطقه هستش .........
    شما چطور از روی این ویدیو میفهمی ......!!! میشه به ما هم یاد بدی در ضمن این ویدیو ماله خیلی پیشه و من بارها اینو دیدم
    تا زمانی که گیم پد تو دستت نباشه و بازی نکنی نمیفهمی
    حدس ....!!
    نمیدونم والا منظور شما چیه
    اگه نباشه جاش خالی می مونه karnavaleroos's Avatar
    Mar 2005
    DreamZ
    کسی میتونه بفهمه این تریلر ماله کدوم ورژنه فقط بگم خیلی خفنه لباسا گل آلود گریه و شادی دست دادن با داور عجیبه خیلی انیمیشن داره
    من تاجایی که یادمه pes 5 و 6 انقدر طبیعی نبودن البته طرف زده pes 2011 اما خود نظر دهنده ها میگن مال pes 2011 نیست کسی میدونه ماله کدوم ورژنه؟
    Oct 2007
    نمیدونم چجوری جواب شما دوست عزیز رو بدم ...
    دوست من تا جایی که یادم هست این ویدیو ماله یکی از نسخه های WINNING ELEVEN هستش که تو PS2 بود و ما میرفتیم کلوپ بازی میکردیم .....
    تا بازی به اینجا برسه هنوز خیلی کار داره این انیمیشن رو خود کونامی ساخته بود برای تریلر اون بازی .....
    Mar 2005
    DreamZ
    عجب
    ولی جالبه اون موقع اینا این ایده ها رو داشتن اما الان نمیتونن یه ایده جدید رو کنن
    اینم ببینید بد نیست فقط یکم بیکیفیته ظاهرا دزدکی گرفته شده
    چیزی که از ویدئوی زیر دستگیرم شده اینه که دیگه دست و پای بازیکنا تو هم نمیره راحت تنه به تنه میشن بدون اینکه تداخل صورت بگیره
  5. #695
    Oct 2007
    عجب
    ددوست من اون فقط یه انیمیشن چند دقیقه ای هستش و بس ....
    دوستان به عکس جدید که از بازی منتشر شده ( عکس زیر ) توجه کنید ..!!!
    به نظره من این استادیوم جدید هستش و تو بازی وجود نداره ...
    شاید این باشه
    UptonPark
    If you compare this movement to PES 2010, you'll see a world of difference, players now seem to actually control the ball like real players. It's sublime.
    تنها دغدغه من تنها اینه که 1. داور بازی مشکلاتش حل بشه 2. درواره بانها مشکلاتشون حل بشه 3. عناصر درون زمین کامل بشن 4.هوش مصنوعی بازیکنان از جمله مدافعین
    خدایا خودت کمکشون کن
  6. این کاربر از google_boy07 بخاطر این مطلب مفید تشکر کرده است
  7. #696
    Mar 2005
    DreamZ
    من فقط دوست دارم گیم پلی نسخه 6 رو این نسخه تا حدودی اجرا بشه خدا کنه اما من نمیدونم اینا تو نسل کارنت میتونستن این گیم پلی رو بسازن اما نسل نکست با اینکه 4 سال ازش گذشته هنوز اندر خمه یک کوچه اند
    یادش بخیر سر بازیکن میشکست بانداژ میکردن پاشون زخمی میشد خون میومد تماشاگرا آتیش بازی میکردن عکس العمل تماشاگرا نسبت به حوادث درون زمین بهتر بود گزارشگر بازی عالی بود
    من یه سوال دارم چقدر ساختن اینکه مثلا مربی بیاد کنار زمین یا عکاسا متحرک باشن یا آب و هوا متغیر باشه یا داور مجهز به گوشی باشه مخصوصا آوانتاژ دادن داور که در نسخه 6 بود من امروز یه عکس از فیفا دیدم داخل زمین ازین کاغذا و روبانایی بود که تماشاگرا اونا رو ریخته بودن یا تیر دروازه یک دست سفید نبود بلکه کمی چمنی و گل آلود بود چی میشد کنامی هم اینا رو تو بازی بزاره اون چیزی که منو میسوزونه اینه که بعضی از این چیزا تو ورژنهای قبلی بود اما الان نیست
  8. #697
    آخر فروم باز amin 2010's Avatar
    خونمون دیگه!!!
    اين تو کدوم نسخه بودش؟؟؟
  9. #698
    Mar 2005
    DreamZ
    pes 6 البته سر در هنگام ضربه سر زدن وقتی کله به کله میشدی میشکست ای کاش عکسی از اون صحنه داشتیم اینجا میزاشتیم
  10. این کاربر از karnavaleroos بخاطر این مطلب مفید تشکر کرده است
  11. #699
    اگه نباشه جاش خالی می مونه hasani2008's Avatar
    10
    ديگه نه در اين حد
  12. #700
    اگه نباشه جاش خالی می مونه UP-SNAKE's Avatar
    IRAN , tehran
    آقا حالت خوبه؟ خون؟ کلشون ميشکست؟ lol ما که نديديم همچين چيزی
  13. 4 کاربر از UP-SNAKE بخاطر این مطلب مفید تشکر کرده اند
