سلام ، یه برنامه میخواستم که فایل های Mpeg رو بچسبونه به هم ؟؟؟؟
اورژانسی
اورژانسی
Ulead.....
VCD Cutter Pro 4
A video player (MPEG/VCD/DVD/AVI/OGG) that can control the playback of video file conveniently and friendly
VCDCutter Pro main features include: support slide show play of picture file; grab picture when you play video file; clip admiring video segment; generate video file screen shot; on-line video broadcast; support window/screen capture; and also send the playing video frame/picture to self-contained simulated video Webcam; and offering a wide variety of other functions.
Here are some key features of "VCDCutter Pro":
· Control playback of the video file conveniently and friendly (including image resize, playback volume control, playback speed control, etc.);
· Clip video file at the time of playback and save the clipped file in AVI/MPG1 format;
· Support clipping and chopping MPG1 file into smaller segments at equal length and combine smaller segments into large segment file;
· Grab picture while play video file (including continuous grabbing);
· Support the slide show playback of picture file and provide numerous change modes of special effects;
· Support video file compression and conversion (compress and convert some video files into AVI format);
· Generate video file screen shot automatically or in batch;
· Send the playing video frame/picture to self-contained simulated video Webcam (Name of device: JiaoCap. This function must be supported by WIN2000/XP. WIN9X does not support.)
· Support online video broadcast of video file and share with friends.
· Support window/screen capture. you can save captured frames as BMP or AVI, or send frames to self-contained simulated video Webcam.
Download:
Mirror:کد:برای مشاهده محتوا ، لطفا وارد شوید یا ثبت نام کنید
يه برنامه كه بتونم قسمت هاي از dvd به 3gp تبديل كنم؟
كار باهاشم اسون باشه
ممنون ميشم اگه كمكم كنيد
یه کامورتور میخام تا فایل های با پسوند mpeg رو به یه فرمت تصویری با حجم کمتر تبدیل کنم.
برای برش از dvdcutter استفاده کن (قبلا درخواست شده سرچ کن)
برای کانورت هم که
مرسی دوست عزیز![]()
سلام من با چه برنامه ای میتونم فرمت صوتی wave sound رو به سایر فرمتهای صوتی مثلا MP3 تبدیل کنم چند برنامه رو امتحان کردم اما متاسفانه از این فرمت پشتیبانی نمیکردند ضمنا اگه ممکنه کمی هم درباره این فرمت توضیح بدید.
